TENMAT high temperature filters are made out of inorganically bonded granular minerals, providing more strength than any other commercially available filter. TENMAT hot gas filter elements are filter tubes developed for operating temperatures up to 1000 °C.
TENMAT manufactures a wide range of element designs in a choice of exonerated refractory materials tailor-made to customer requirements. Without the use of asbestos or ceramic fibres, TENMAT Candle (CS1150F) and Big Tube filters (CS1255F) comply with the highest environmental emission standards worldwide.
Plant Engineering:
Filter plant engineering will depend upon a number of key conditions, including the required temperature of operation, the gas volume and the chemicals involved. TENMAT can recommend HGF system builders. Request our ‘INSTALLATION AND OPERATION MANUAL for TENMAT Hot Gas Filters’ for advice.
Proven Solution:
With over 15 years of experience and hundreds of thousands of filters successfully installed, TENMAT hot gas filter elements have an excellent track record
TENMAT high temperature filters are made out of inorganically bonded granular minerals, providing more strength than any other commercially available filter. TENMAT hot gas filter elements are filter tubes developed for operating temperatures up to 1000 °C. TENMAT manufactures a wide range of element designs in a choice of exonerated refractory materials tailor-made to customer requirements. Without the use of asbestos or ceramic fibres, TENMAT Candle (CS1150F) and Big Tube filters (CS1255F) comply with the highest environmental emission standards worldwide.
Plant Engineering:
Proven Solution:
Hot Gas Filtration – Additional Info
- High temperature capabilities operating up to 1000 °C
- High filtration efficiency – Typically 99.99%
- Resistant to most chemicals
- Thermal shock resistant
- Cleaned by reverse pulse
- Self supporting – no metal cage needed
- Totally incombustible – spark and fireproof
- Hot gas energy recovery
- Improve process efficiency
Atmospheric Pollution Control
- Incineration of industrial, clinical and chemical waste
- Incineration of animal carcasses
- Soil remediation
- Cement and brick manufacture
- Metallurgical processing – ferrous and non-ferrous
In Line Equipment Protection
- Pressurised Gasification – Syngas Cleaning
- Biomass Gasification
- Pyrolysis
- Heat Exchanger Protection
- Catalyst Life Extension
Application | Material |
Incineration of industrial, clinical and chemical waste | CS1150F / CS1255F |
Incineration of animal carcasses | CS1150F / CS1255F |
Soil remediation | CS1150F / CS1255F |
Cement and brick manufacture | CS1150F / CS1255F |
Metallurgical processes | CS1150F / CS1255F |
Crematoria | CS1150F / CS1255F |
Our network of distributors outside of Europe and America will ensure first class local service and availability.
Australia | FilterCare Technical Textiles Pty Ltd. | T: +61 2 9676 2000 | E: info@filtercare.net |
India | Alfa Therm Ltd | T: +91 1128114748 | E: alfatherm@vsnl.com |
Japan | SKW East Asia | T: +81 (0)3-3288-7351 | E: info@skwea.co.jp |
Malaysia | ENVIRO FILTRATION SDN BHD | T: +6019-720 9189 | E: enquiry@enviro-filtration.com |
Hot Gas Filtration
Additional Info
- Soil remediation
- Pyrolysis
